Hi all,
I've a File Personal Gdb with a blob field in a table (table, not featureclass). I need to migrate to personal sde/sql express.
I'm trying to do it exporting the file gdb in xml and importing the xml, but I catch the error:
"import xml failed FDO error: -2147186428 .... Maximum BLOB size exceeded [field name]
I'm using ArcGis 9.3 and SQL Express 2005.
I found, on the ESRI support site, a reference to a configuration file for SDE (unfortunately only enterprise version) where you can increase sizefrom the default (1000000 bytes) to another value, but I haven't found anything for the personal/sql express...
Thanks in advance for any suggestion!
Marco Belotti
CESI spa
Italy
