HEC-GeoRAS Beta for ArcGIS 10.2
17446
15
01-27-2014 10:41 AM
AmitSinha
A new HEC-GeoRAS build for ArcGIS 10.2 is available at
https://mft.esri.com/incoming/HECGeoRAS/Setup10.2_Beta/10.2.0.2/
I tested this out using a dataset near Sacramento (Baxter), and all tools checked out fine. I was able to export GeoRAS data, import to RAS, and then import RAS results into HEC-GeoRAS. A few things you should consider:
�?� If you are using a personal geodatabase, make sure that you upgrade it to the current version of ArcGIS 10.2, otherwise you may get a failure while exporting GeoRAS data.
�?� The geodatabase should not contain raster datasets within it even though it is permitted. I have heard of export failure associated with it.
�?� File geodatabase format is recommended, but personal geodatabase should work fine as well.
You can log using the following credential:
https://mft.esri.com/EFTClient/Account/Login.htm
Login: ADSRiverHydraulics
password:  ADSRiver.2013b
Let me know if have problems installing and running the application.
Amit Sinha
Esri, Inc.
miketodd
Hi Amit,
Is this link still running? I am unable to successfully log into the FTP. I am using the username and password provided, however, I get a critical error saying 'Authentication Failed' and then 'Could not connect to server'....Please advise if this download is still available.
Thanks.
V_StuartFoote
MVP Frequent Contributor
Mike,
Try again, just verified site is up an functional with the new credentials (wef. 11 March 2014) as found here: http://forums.arcgis.com/threads/104391-New-password-for-Arc-Hydro-ftp-site-March-11-2014?p=372117&v...
Note though that incomming folder has been renamed camp.  So the /incoming/HECGeoRAS/Setup10.2_Beta/10.2.0.2/ has become /camp/HECGeoRAS/Setup10.2_Beta/10.2.0.2
Stuart
SaraRastgou
Hi ,
I just started using ARCGIS 10.2.2 and I need a Hec-geo ras extension for that. Would you please help me.
Sara
V_StuartFoote
Sara Rastgou
The MFT site has current build -- HECGeoRAS 10.2.0.10  beta. Instructions for access are in this post -- https://community.esri.com/message/402547#402547  and then navigate to /camp/HECGeoRAS/Setup10.2_Beta directory.
An alternative http based download is here downloads /archydro/HecGeoRAS/10.2/
but this site is not kept as current  (at present the HECGeoRAS builds posted are the same).
Stuart
SaraRastgou
Many thanks for your quick response. I was so impressed.
Appreciate your help.
Sara.
RuthOla
Hi.
Thanks for posting the download link. I have downloaded and installed the HEC GeoRAS.
I was able to convert the sdf to xml and do the layer set up. The import RAS data keep giving error as shown below. Please what am I doing wrong?
MikkoSane
I had almost the same error (I downloaded the software from http://www.hec.usace.army.mil/software/hec-georas/downloads.aspx, not beta anymore).
Starting format transformation
Transforming to internal format
Validation internal format
Transforming to GDB format
Creating Geodatabase
Unable to cast object of type 'System.__ComObject' to type 'ESRI.ArcGIS.DataSourcesGDB.FileGDBWorkspaceFactoryClass'.
    at ESRI.APWR.GISXDE.ArcGISCommun.Workspaces.WSFactory.Create(WSConnectionParams conParams)
   at ESRI.APWR.GISXDE.Importer.GDEImporter.Import(XmlReader source, GDEImportFormat format, WSConnectionParams connParams) Failed to import RAS data!
Mikko
V_StuartFoote
@Mikko,
Not sure it is root of your issue, but it is still a better bet to use the Esri Water Resources Group MFT (sftp) community repository for the current installers rather than the HEC downloads which tend to be un-patched.
The USACE HEC -- project site is currently posting an older HEC GeoRAS build, 10.2.0.2 with ApFramework 10.2.0.7, built 2013-12-20
The Esri MFT site currently posts HEC GeoRAS build 10.2.0.10 with ApFramework 10.2.0.16, built 2014-06-05
Review the readme.doc file posted to the MFT is usually will describe issues addressed with patches and dates released--although it looks a little out of date at the moment ( Christine Dartiguenave ?).  Anyhow,  you'll need to pay attention to the ApFramework if you have other Water Resource Group projects like ArcHydro installed.
Stuart
BishwaMishra
Hi Stuart
Currently I am using ArcGIS 10.1 and HecGeoRAS 10.1 and want to upgrade to ArcGIS 10.2.2 . Just wondering if HEC GEORAS 10.2.0.10 works with ArcGIS 10.2.2.
Bishwa
