Question on AGSGDBGeodatabase?
2357
01-28-2014 10:12 PM
c_f_ong
New Contributor III
Hello
I've used ArcGIS Desktop 10.2.1 to generate a local geodatabase and added it to my project. Please refer to below for the code I've used to access the geodatabase. However, I've encountered an error as shown below.
    NSArray *paths = NSSearchPathForDirectoriesInDomains(NSDocumentDirectory, NSUserDomainMask, YES);
    NSString *docsPath = [paths objectAtIndex:0];
    NSString *path = [docsPath stringByAppendingPathComponent:@"route_points.geodatabase"];
    NSError *err = nil;
    AGSGDBGeodatabase *gdb = [[AGSGDBGeodatabase alloc] initWithPath:path error:&err];
    NSLog(@"error %@", err.description);
error Error Domain=com.Esri.ArcGIS.ErrorDomain Code=10003 "SELECT ObjectID, Definition, Type FROM GDB_Items WHERE Name = ? collate nocase AND  Type = ?
Any idea what maybe the cause? Any solution?
Thanks.
Rgds
Ong CF
DiveshGoyal
Would you be able to share the geodatabase so that we can investigate?
AndriyGalushka
New Contributor III
Hello
    NSError *err = nil;
Thanks.
Rgds
Ong CF
Add you "route_points.geodatabase" in TARGETS/project target/Build Phases/Copy Bundle Resources/
