Traceback (most recent call last): File "C:\Users\talmeida\AppData\Local\ESRI\Desktop10.1\AssemblyCache\{BB229966-100D-4482-A3FE-B298BD262597}\AddPoints_addin.py", line 18, in onMouseDownMap edit = arcpy.da.Editor(workspace) RuntimeError: cannot open workspace
import arcpy import pythonaddins import os from arcpy import env class Add_points(object): """Implementation for AddPoints_addin.Add_points (Tool)""" def __init__(self): self.enabled = True self.cursor = 3 # Can set to "Line", "Circle" or "Rectangle" for interactive shape drawing and to activate the onLine/Polygon/Circle event sinks. def onMouseDownMap(self, x, y, button, shift): fc = "TonyTwoWay.DBO.CCAP_TEST" workspace = r"Database Servers\DSD15_SQLEXPRESS.gds\Tony_Two_way" arcpy.env.overwriteOutput = True # Start an edit session. Must provide the worksapce. edit = arcpy.da.Editor(workspace) # Edit session is started without an undo/redo stack for versioned data # (for second argument, use False for unversioned data) edit.startEditing(True) # Start an edit operation edit.startOperation() list = [] with arcpy.da.SearchCursor(fc, ["AddressID"]) as cursor: for row in cursor: list.append(int(row[0].strip("CC"))) del cursor list.sort() AddressID = list[-1] + 1 AddressID = 'CC' + str(AddressID) row_values = [(x, y, (x, y), AddressID)] cursor = arcpy.da.InsertCursor(fc, ["X_Coord", "Y_Coord", "SHAPE@XY", "ADDRESSID"]) for row in row_values: cursor.insertRow(row) del cursor arcpy.RefreshActiveView() # Stop the edit operation. edit.stopOperation() # Stop the edit session and save the changes edit.stopEditing(True) pass
Solved! Go to Solution.
workspace = r"Database Connections\<connection name>.sde"
Traceback (most recent call last): File "C:\GIS\Python Scripts\AddPoints_updateXY_AddressID.py", line 30, in <module> row_values = [(x, y, (x, y), AddressID)] NameError: name 'x' is not defined
Traceback (most recent call last): File "C:\Users\talmeida\AppData\Local\ESRI\Desktop10.1\AssemblyCache\{BB229966-100D-4482-A3FE-B298BD262597}\AddPoints_addin.py", line 32, in onMouseDownMap list.append(int(row[0].strip("CC"))) ValueError: invalid literal for int() with base 10: 'IDCCD08_FIRE'
fc = "TonyTwoWay.DBO.TT" workspace = r"C:\Users\talmeida\AppData\Roaming\ESRI\Desktop10.1\ArcCatalog\Connection to dsd15_sqlexpress.sde" # Start an edit session. Must provide the worksapce. edit = arcpy.da.Editor(workspace)
