Solved! Go to Solution.
For the token issue, it looks like your address search endpoint requires a token. The easiest fix would be to change the security on that service so that it no longer requires a token. Otherwise you'll need to either use the IdentityManager object in your JavaScript code to have the user log in, or, if you don't want users to have to log in, handle the login on the server-side using a proxy.
Hi Michelle,
You may be running into a bug, NIM084485.
Synopsis
In the Land Use Public Notification local government template, there are improperly defined workspaces in the GenerateCSV and GenerateAveryLabelsPDF tools in PublicNotification.tbx.
Additional Status Information
Fixed in the November 2012 Release
Alternate Solution
Edit the script tools to be published as geoprocessing services for the Land Use Public Notification local government template to use the %scratchfolder% environment.
