Which operations (e.g., Create, Delete, Update, Query) have you specified as 'allowed' for Feature Access within the service properties? Also, you should check the requests and responses using Fiddler. What are the results from running Fiddler during the attempt to add the new feature?
Fiddler is a free web debugging proxy which logs all HTTP(s) traffic between your computer and some host (e.g., your GIS server). You can use it to debug traffic in order to see the content of requests and responses so you can identify where the failure might be. Download the appropriate version of the Fiddler software here. Open Fiddler, then re-try your add feature operation, then save the results to a SAZ file in Fiddler and post it here.
