Offline definitionExpression
4015
8
04-25-2014 07:05 AM
RobFisher
I am moving a working iOS application to incorporate offline features.  I was using a definitionExpression on a feature layer to display only certain features when showing the map to simulate two different layers that share the same base table.
Moving the layer to a geodatabase and loading it as a AGSFeatureTableLayer I cannot seem to figure out how to replicate this filtering via a definitionExpression to show only one set of features on the map at a time.
Is this currently possible?
Rob
DiveshGoyal
We currently don't have a way to filter features using a definitionExpression on AGSFeatureTableLayer. We hope to add this in an upcoming release.
You can manually toggle the visibility of features by using setVisible:forFeature: on AGSFeatureTableLayer
See https://developers.arcgis.com/ios/api-reference/interface_a_g_s_feature_table_layer.html#a5528e48638...
RobFisher
Is it even possible to set the visibility of offline features from an AGSFeatureTableLayer?  I can get a NSArray of the features I want to hide but they get returned as an AGSGDBFeature which has no visibility property.
Perhaps I'm not accessing the features via the right method but I can't see how to make a feature invisible which seems wrong.
DiveshGoyal
MichaelDavis3
Occasional Contributor III
Are there any plans to implement a definition query functionality in the future?
Setting visibility works, but cycling through every feature in a large-ish layer (13,000 points) is proving to be quite resource intensive and slow when running on a device.
DiveshGoyal
Yes, its definitely something we want to provide.
MichaelDavis3
Thanks Divesh - From your answer I'll infer that this is something that might be in a future release, but probably won't be in this magical "Quartz" release Esri folks keep mentioning.
DiveshGoyal
We hope to add it in Quartz
Nicholas-Furness
Hey Rob,
FYI: definitionExpression was added to AGSFeatureTableLayer in 10.2.5 of the ArcGIS Runtime SDK for iOS.
Release notes for 10.2.5—ArcGIS Runtime SDK for iOS
Cheers,
Nick.
MichaelDavis3
This is fantastic - thanks Nick!
