function getStatsHandler(results){//formats the results for line chart, then generates it stats.length = 0; yearList.length = 0; rateList.length = 0; var year; domConstruct.empty("chartDiv"); for (i=0;i<results.length;i++) { var lyrResult = results; itemLength = lyrResult.layerName.length; yearPos = itemLength - 4; year = lyrResult.layerName.substr(yearPos, 4); var rate = lyrResult.feature.attributes.RATE; yearList.push({value: i+1, text:year}); rateList.push(parseFloat(rate)); }; rateList.sort(function(a,b){return a-b}); var maxVal = rateList[rateList.length -1]; maxVal = Math.round(maxVal); var axisMax = (parseInt(maxVal/10)+1)*10; var lineChart = new Chart2D("chartDiv", { title: currentCounty + "</br>" + title + " Rates" , titlePos:"bottom", titleGap: 12, titleFont: "normal normal normal 13pt Arial", }); lineChart.addPlot("default", { type: "Lines", markers: true, hAxis: "x", vAxis: "y"}); lineChart.addAxis("x", { title:"Rates by Year", titleOrientation:"away", labels: yearList, font: "normal normal normal 9pt Arial", majorLabels: true, minorTicks: false, minorLabels: false, microTicks: false }); lineChart.addAxis("y", { title:rateNote, vertical: true, fixLower: "major", fixUpper: "major", min: 0, max: axisMax, minorTicks: false, minorLabels: true}); //{vertical: true, min: 0, max: axisMax}); lineChart.addSeries("Series 1", rateList, { stroke: { color: "red", width: 2 } } ); var tip = Tooltip(lineChart, "default", { text : function(o) { var yr = yearList[o.x].text; var yrList = parseInt(yr) - 1; return ( yrList +'<br>' + o.y ); } }); lineChart.render(); }
Solved! Go to Solution.
I figured it out! If you increase the length of the x Axis slightly, it won't cut the point off. I did this in my example by adding 0.5
var xAxisMax = years.length + 0.5; //extends the X axis so it doesn't crop off the point | |
Hey, I'm in the same situation and I liked the solution, but didn't understand where did you use that xAxisMax variable; could you show? Thanks
I don't think I've touched this since I posted it, but in my code it looks like I added right after the line where I set the xAxis
var xAxisMax = years.length + 0.5; //where years is the array holding the data from my identify, extends the X axis so it doesn't crop off the point
Then you add one more parameter in the X axis definition of the lineChart:
max: xAxisMax,
In my post, I have data by year, so 'years' is the name of my array. You'll need to study your data to determine what variable you have to work with.
I have data by month/year and tried to add +0.5 to max too, but didn't work very well. See before and after prints:
Before:
After:
See that the first marker is still cropped and the top y axis one (value above 50) is too (this one I know that is not solved with max in x axis).
I think you can calculate the maximum value of the y axis too. Have you tried another constant besides 0.5? That was a value that worked for me, but your range of values might require something different.
Here are the links I used when I was doing my research:
| A Beginner’s Guide to Dojo Charting with AMD, Part 1 of 2 | Blog | SitePen
| Dive Into Dojo Charting Again | Blog | SitePen
Maybe you'll find something useful.
Thanks Tracy, I got it working with the explanation of Scaler in your first link
The graphic looks right, but are those the correct values on your Y axis? They're nothing like your original numbers.
There seems to be quite a lot you can do with this chart object, but almost no documentation to go along with it.
Hey Tracy, yes, they are correct. My data are dynamic, so I calculated max similarly the way you did, with some gap to avoid the cropping.
I agree with your comments about documentation, I felt lack of updated explanative docs with rich samples.
Is it possible to do this with Media Infos in the popup template? I'm trying to add an x-axis to my data.
I have a counties layer with different years of data. Please advice!
Here are some snips of my results.
Thanks for all your help!
