Reviewer Processing Error
4461
05-27-2014 02:47 PM
Kenai_Watershed_Forum_
After running a batch file I receive the following error: "Error updating batch run table. Edits not saved." Opening the Reviewer table confirms that there are no errors being saved or returned.
I'm running ArcGIS 10.1 Data Reviewer for Desktop
     ArcGIS 10.1 Service Pack 1 Data Reviewer for Desktop
     ArcGIS 10.1 SP1 Patch 3
     ArcGIS 10.1 SP1 Patch 6
Any thoughts?
KumarBhardwaj
Occasional Contributor II
Can you please confirm the type of Reviewer workspace you are using? Is it a File Geodatabase or SDE(Oracle, SQL Server) workspace.
If it is a SDE Reviewer workspace then please confirm if you have followed the steps mentioned here.
MichelleJohnson
On the top of my head, there could be two possible issues.
  1. Are you in an edit session when you are running the batch job? Not that this is an issue.  But if your Reviewer workspace is in a different geodatabase than what you are editing, then this could be the issue.
  2. If the Reviewer workspace is in an enterprise geodatabse (as Kumar questioned), are the permissions set up properly for each Reviewer table? Refer to the link that Kumar provided.
maherelayyan2
Michelle,
I am still waiting for a solution for the problem , can you tell technical support , i sent you an email about this.
