Esri Maps for Office and Portal Configuration
9283
10
06-13-2014 01:46 PM
RobMiller
I have just downloaded Esri Maps for Office to test it out and when I open Excel and click on the Esri Maps tab, I get the following error:
Functionality such as the following will not be available due to the configuration of your Portal for ArcGIS
  • Share Map
  • Share Layer
  • Add Excel Data using the Address Location Type
  • Select Features by drawing a rectangle
  • Find Near Selection
Currently I have Portal for ArcGIS configured to use Windows Integrated Authentication and I have a federated ArcGIS Server with it.  I cannot determine what about my configuration is causing this issue.  If anybody has any suggestions about what might be the issue I would greatly appreciate your help.
Thank you,
Rob
ChrisMartin7
Rob,  Did you ever get this figured out?  I'm having the same problem.
Thanks much,
Chris
ScottBall
Hi -
I'm a product engineer on the Maps for Office dev team. Just saw your question and passed it along to some of the other folks on the team that are more familiar with Portal. According to them, it sounds like "the Portal this user is connecting to is not configured with a dedicated hosted server. As I do not see that in his description. Also we show these messages when we could not identify a hosted server configured in the Portal."
You can find more information about configuring hosting servers at the following help link:
http://resources.arcgis.com/en/help/main/10.2/index.html#//017s0000006n000000‌
Let me know if this helps!
Scott
RobMiller
Hi Scott,
I really appreciate your response. This is helpful. So basically much of
the functionality for ESRI Maps for office requires a hosted server on
Portal for ArcGIS or using tokens to publish services to ArcGIS Online?
Rob
ScottBall
That's correct, you'll need a hosted server to use most of the Maps for Office functionality.
AlainGagnon
HI Scott.
My ESRI Maps for Office used to work great.  I had an ESRI consultant install Portal, that it did not work for some reason we are trying to figure out.  Portal was installed but ever since then I am getting the same error message.  The Server and my desktop were re-stated after the uninstall, still getting the error message.
Any ideas?
Much appreciated,
Alain
ChrisMartin7
Alain,
I think you may want to run through or double check the steps here​ArcGIS Help (10.2, 10.2.1, and 10.2.2) . For some reason I seem to recall having to reconfigure the hosting server at one point for a similar issue.
-chris
AlainGagnon
Thanks Chris,
We will give it a shot.
Alain
S/Sgt. Alain Gagnon, s.é.-m
Royal Canadian Mounted Police
National Operations Centre
NCO i/c Geospatial Intelligence Section
Gendarmerie Royale du Canada
Centre national des opérations
S/Off. responsable, Section des renseignements géospatiales
Tel: (613) 993-0236
Cell: (613) 227-2083
email/couriel: alain.d.gagnon@rcmp-grc.gc.ca
>>> Chris Martin <geonet@esri.com> 2015/04/14 10:06 PM >>>
GeoNet (
http://jiveon.jivesoftware.com/wf/click?upn=Dg1s4x8le7Lmxv8KWGaqo8h7SGfRSMkw-2FpvHGF9-2FW3rK-2Bvs1kL9-2FnG6jjf2NZhrLDz0M-2BrY-2By9IaziQEKVk3Hg-3D-3D_xNOXY5GzhE4ux-2BUgfTC4wpeIsUG9PGz9XEQqgaH-2FQvT31rm6llApQNstnuYKbFNWCJ1hyVeOmds7calv42no7-2BAFxkwbkfFYdewU6VgkMs-2FIdmI5wgHGfXwoT4HM0kRSJEoVctjMDn7CBLC-2FGfVYXMrz-2BbP73sUNvP7GWpJshqzMlRFzsL4b-2F2OcKymvTu8ZoorsgSNLJpV0uOcLrWkuEiaepY3KK0pfVNbke2r0SEokYO94rIpIR2g7743T6Dx6jniOkhGflb-2FMOD9x24dmdlsrF9K5-2FsGBzlj-2BjqxdE4TJWXL0dvJ6BSiQJMw6bXshnL40cm4lItpGW1yQUmEyng-3D-3D
reply from Chris Martin (
http://jiveon.jivesoftware.com/wf/click?upn=Dg1s4x8le7Lmxv8KWGaqo7A4BXwO9PY1WvQ5cXCtK4-2BYzp-2F-2BWdIWc1pmOC4Pj8f0EWBXnC0u7w6SnpQXKVs0sIaxSEOwaIsqdorSl29n8kRHeSd1KfZSnruTX5PU9c-2FH_xNOXY5GzhE4ux-2BUgfTC4wpeIsUG9PGz9XEQqgaH-2FQvT31rm6llApQNstnuYKbFNWCJ1hyVeOmds7calv42no7-2BAFxkwbkfFYdewU6VgkMs-2FIdmI5wgHGfXwoT4HM0kRSJEoVctjMDn7CBLC-2FGfVYXEtqTk1npWztogUOs36NBdSQ8AH9LZ5zYnWsDzWzwhlnCkkuUiyEsn6rZFnmWNqcEfWxw2nN67akAzPIkr8WQKmub9c-2Fc-2Fuw0p9ENZMIVQmyIstxZ5hLfDzOty-2Bkl-2B5oE2kW5fuNfJU8baE37mb9ifwpsKFLDVFV8zIrtZWgafBkm0vyulDYu1HkTbnNy94aPg-3D-3D
) in Esri Maps for Location Analytics - View the full discussion (
http://jiveon.jivesoftware.com/wf/click?upn=Dg1s4x8le7Lmxv8KWGaqo0VQjeJBYpG9HGC8QZBT-2FEwHhSbh5KZOE0CDcHl5MmB6Uft0vpHwPRxXVSKbXLtF6-2Fz74ROfziUWLttaBM-2F628c-3D_xNOXY5GzhE4ux-2BUgfTC4wpeIsUG9PGz9XEQqgaH-2FQvT31rm6llApQNstnuYKbFNWCJ1hyVeOmds7calv42no7-2BAFxkwbkfFYdewU6VgkMs-2FIdmI5wgHGfXwoT4HM0kRSJEoVctjMDn7CBLC-2FGfVYXD9YMKjagdEG-2FR0eE5lMlQsw7NM-2FYJAvRgqON9HtINKjX6kvwQrd-2FVx3vBkwRPZviaCCpKfkDrC-2FxIDieE4-2BsXiGkSIz1UYqCclFLYsmKqXO-2FY7gXYjJCZYiXm9PR86jHWO6u6LqAU8szKuwZG8p4DedOzCGofyNHz5VwspFCELmMpE52LAxO0xkCfmHMfFYpQ-3D-3D
Alain,
hereArcGIS Help (10.2, 10.2.1, and 10.2.2) (
http://jiveon.jivesoftware.com/wf/click?upn=kM-2FmEH7VSq4tvrUHFOpKHsaL-2Bhbf0FdFp-2FjCYbg0shEtYwE93JoOXs2jEakUqgv7C8TiABgJ3XGLbQfmn8ZNeHLLyK49g5Svuh9St2nTUFkpA9xVWZTaI2Vfguua1Yhr_xNOXY5GzhE4ux-2BUgfTC4wpeIsUG9PGz9XEQqgaH-2FQvT31rm6llApQNstnuYKbFNWCJ1hyVeOmds7calv42no7-2BAFxkwbkfFYdewU6VgkMs-2FIdmI5wgHGfXwoT4HM0kRSJEoVctjMDn7CBLC-2FGfVYXEXb2IZ3hlcTBUPQaXl0ZLbRkT95B7-2FKfHQw4VLzNaTtqZB4K2QByLartaiJilGqqMQtiwP13Ddv-2F5yyBqE4k5NTQTReCAlgfQutR9ZIW-2Fc2Jf9Fvqu2IQUddbZRul5DsIM8LlHDoLMQA9397IdLND9WdgS3UfHwUeK0t99FsnqB75NBmTh5pp8TJBMMLzAzxw-3D-3D
-chris
Reply to this message by replying to this email, or go to the message
on GeoNet (
http://jiveon.jivesoftware.com/wf/click?upn=Dg1s4x8le7Lmxv8KWGaqo0VQjeJBYpG9HGC8QZBT-2FEwHhSbh5KZOE0CDcHl5MmB6Uft0vpHwPRxXVSKbXLtF6-2Fz74ROfziUWLttaBM-2F628c-3D_xNOXY5GzhE4ux-2BUgfTC4wpeIsUG9PGz9XEQqgaH-2FQvT31rm6llApQNstnuYKbFNWCJ1hyVeOmds7calv42no7-2BAFxkwbkfFYdewU6VgkMs-2FIdmI5wgHGfXwoT4HM0kRSJEoVctjMDn7CBLC-2FGfVYXJLpLjRAPEMV-2B3NF7BrDsV-2FqyKIIBNmoeabHVusdIv5HIxvcmAfQmvu-2FEhkE5dlVc4VH4kln9EdVC78SmuwJWxjH4II9EVB-2BzUVthFUZLWaMxCxU-2FZOgHu0c9XEe5rwUj2nEPrzDxHplam2ahHotFxnx38Wxp9Iesl9zINyZT2BjU64c0xmgpcSjZnC9AIcCug-3D-3D
Start a new discussion in Esri Maps for Location Analytics by email (
mailto:discussions-community-gis-analysis-esrimapsforlocationanalytics@mail.geonet.esri.com
) or at GeoNet (
http://jiveon.jivesoftware.com/wf/click?upn=Dg1s4x8le7Lmxv8KWGaqo4sRZhdUvuzKLb2NK-2Ftfk4Da8JoaqoqWY57fX5AF0bwqNMGpm-2FlIN02rUzlNelCybkXkVqH7q-2BLt6cvmcLq7uQgBcCjABFEU-2BRY7gAcrIw5-2BYLBqUnzApV4lBixbO5aBHV00AV-2BgJRIkaRnyfeHghfQ-3D_xNOXY5GzhE4ux-2BUgfTC4wpeIsUG9PGz9XEQqgaH-2FQvT31rm6llApQNstnuYKbFNWCJ1hyVeOmds7calv42no7-2BAFxkwbkfFYdewU6VgkMs-2FIdmI5wgHGfXwoT4HM0kRSJEoVctjMDn7CBLC-2FGfVYXBOQtOUd-2BHSB-2BxbJ4Nk1WoLDifpLQs6vuvlGNAIElqCZJwLg9kKvwY3v2eFbFU26JHWTniZdvRdYIcOlVpQrJY-2FAuCG1rjCk2nTOCd0rM-2FLtriLcsvlVSfRDL7DLYsgWw55gMlrjZrL9spTf0f6P1-2B6TOeovEs4EXIvxWQrcEo6RSUtXC3cEj-2B1dvkOAbQrjaQ-3D-3D
Following Esri Maps for Office and Portal Configuration (
http://jiveon.jivesoftware.com/wf/click?upn=Dg1s4x8le7Lmxv8KWGaqo0VQjeJBYpG9HGC8QZBT-2FEwHhSbh5KZOE0CDcHl5MmB6Uft0vpHwPRxXVSKbXLtF6-2Fz74ROfziUWLttaBM-2F628c-3D_xNOXY5GzhE4ux-2BUgfTC4wpeIsUG9PGz9XEQqgaH-2FQvT31rm6llApQNstnuYKbFNWCJ1hyVeOmds7calv42no7-2BAFxkwbkfFYdewU6VgkMs-2FIdmI5wgHGfXwoT4HM0kRSJEoVctjMDn7CBLC-2FGfVYXMM8cBHXifpAZB36Xqx5HE3MzPUnX86c3ubtrFfnFEk-2FS3xOP-2BIE00zdNWr7GLkbEMtqs4NQBiLcjOn7nML47skSIXA9U805aBL4QzlHeNXNK1fSimnlUFIJsHMraSuIrJ6vk43L8TXUIcCz55D4phcKcBQ4ObqA7b2YXHzyVd-2BNUXEE-2BoCUSKISrMHgbSRBdw-3D-3D
) in these streams: Inbox
This email was sent by GeoNet because you are a registered user.
You may unsubscribe (
http://jiveon.jivesoftware.com/wf/click?upn=Dg1s4x8le7Lmxv8KWGaqo4pqG92YCUD-2BIlhNV9k5DBV83sSb-2BDGI8rWn6CHKl29dwpCClxQnjtGpju391D2hFoYdiGncni8GoNdhOGDhpK7wU8KjhFuKC6drlVzBBYcfAPWTg121tz-2BPmJo0g2a58vteomhP48KYy3ccOq1D5iJvgxjrMvfwmKVHamudbDoY7b-2FEvWqfJzT48zjMvjl8Wg-3D-3D_xNOXY5GzhE4ux-2BUgfTC4wpeIsUG9PGz9XEQqgaH-2FQvT31rm6llApQNstnuYKbFNWCJ1hyVeOmds7calv42no7-2BAFxkwbkfFYdewU6VgkMs-2FIdmI5wgHGfXwoT4HM0kRSJEoVctjMDn7CBLC-2FGfVYXC-2B34wnYd4Evmd-2FL7ny9r2vIY5zt8vjm-2FgNK-2Bna3-2F32PCmjPVKCsYO2ZeY-2BTb2-2Bxwn8lKGQ7RCHj-2Bptd7MICJFZ6lwOSrCkYD-2FEZy7mGkb9nKG8utkVCdOaZ0aliXV965X2hLF3Bx2C95TrI1zsKAk1U24-2BfByMNjAAfKzB5Zl-2Bgs3SCFtyhqg7evnkF8g0HUA-3D-3D
) instantly from GeoNet, or adjust email frequency in your email
preferences (
http://jiveon.jivesoftware.com/wf/click?upn=Dg1s4x8le7Lmxv8KWGaqo4pqG92YCUD-2BIlhNV9k5DBUDqBK0wWzVXAg0EgRtio-2BK61CwhTjaWr9OPMIfz2H1Cw-3D-3D_xNOXY5GzhE4ux-2BUgfTC4wpeIsUG9PGz9XEQqgaH-2FQvT31rm6llApQNstnuYKbFNWCJ1hyVeOmds7calv42no7-2BAFxkwbkfFYdewU6VgkMs-2FIdmI5wgHGfXwoT4HM0kRSJEoVctjMDn7CBLC-2FGfVYXHTxQ4V9xQOGpZE9Z2XsHFERh-2Fy93CPhqnv4P0nvX0gpA0qvDfeDlMf-2BGflExj4UOB8Uf9WfMF0NQb2-2Bpf8P6ETP9CjbqXE-2Fcjdt1pK-2BtaH4Y0wzo6DXSYBS4VJBnRVfOFGnBOzLoNqT-2FjmLcuQ419FsahG412yslfFc2m7DDPxsAaFn2-2FZS0JQ8i3HkfzL6-2BQ-3D-3D
ChrisMartin7
Great - good luck.  Some other things you may want to double check if you haven't already.
Working with Portal—Esri Maps for Office | ArcGIS
AlisonGaiser1
We have the same problem here. We do not use portal but instead just ArcGIS Online.
Did the privileges recently change? I am trying to follow the chart found on Configure ArcGIS Maps for Office—ArcGIS Maps for Office | ArcGIS  to determine what I need to use. We want our users to geocode using our internal geocoders - and not one from Esri. This is the default geocoder for my profile on ArcGIS Online.
Any suggestions appreciated,
   Alison
