Python Errors in IDLE when processing metadata
2455
06-15-2014 01:01 PM
IvanBrown
New Contributor III
Scripting ImportMetadata_conversion in Python worked for me with ArcGIS Desktop 10.1.  Now ImportMetadata_conversion won't run in script;  I am now on ArcGIS for Desktop 10.2.2.  I get "ERROR 000816: The tool is not valid."
Although problems with scripting metadata processes might not be very significant in some organizations, my organization provides a GIS data clearinghouse.  Metadata processing is a significant part of our work.
I was disappointed because the ImportMetadata_conversion Help document in ArcGIS for Desktop did not indicate that the tool won't work in an external script.  I wrote a script that uses ImportMetadata_conversion, and then discovered that ImportMetadata_conversion won't run in the script.
curtvprice
MVP Esteemed Contributor
These tools are not supported currently in 64 bit arcpy. This is one of the limitations of 64 bit geoprocessing.
If you launch 32-bit Python and import arcpy, these metadata tools will work fine.
AndresCastillo
MVP Regular Contributor
