Symbol Property Editor will not display Character Marker Symbols
12106
15
08-06-2010 06:19 AM
RasheedKhaleel
New Contributor III
We just upgraded to ArcGIS 10 and whenever I try to change point feature symbology, Character Markers will not display, and I cannot edit point symbols beyond size, color, and masks of existing symbols. I've tried rolling back to 9.3 but no dice. Please advise.
JohnMcKinnon
Having the same problem... the Symbol Property Editor is missing the "control boxes" for "Character Marker Symbols".  I can not pick a font or a subset.
WayneRunkles
Me too! Any solution yet?
RasheedKhaleel
New Contributor III
Still no solution on my end. Other machines work, uninstalling on mine and reinstalling does not work.
WinstonSastroredjo
is there a solution for this problem....i am also encountering it...
Olivier_MOUGEL
I'd got the same problem but desactivating this ATI option solved it.
Thank you for this advice
Olivier MOUGEL
Gironde County
France
GregHawker
I've upgraded to 10.2.2 and now have the same problem. What were the steps you took to fix this problem?
I also have a new PC. So I'm not sure if it is a software or a hardware fix.
Greg Hawker
New Zealand
BrianKaplan
Changing the ATI options fixed it for me and the instructions are here. http://gis.stackexchange.com/questions/85840/why-are-character-marker-symbol-dialog-not-showing-up-i...
GregHawker
Thank you.
Interestingly I had just deleted my normal.mxt for another reason the day before receiving your email and that did indeed fix that problem I had as well.
Cheers and regards
Greg Hawker
Geospatial Information Analyst
Information Services Unit
Otepoti \ Dunedin Office
Department of Conservation
DDI: +64 3 474 6914 | VPN: 5614
Conservation for prosperity Tiakina te taiao, kia puawai
www.doc.govt.nz<http://www.doc.govt.nz/>
BrianKaplan
Now I'm on a different computer at work with a different graphics card and the same issue with the Character Markers not showing up is happening.  I deleted the normal.mxt and that did not solve it. The solution for me on this NVIDIA QUADRO 4000 was to install the latest device driver (version 341.05
