Setting the field OBJECTID as an identity for autoincrement
11089
17
10-28-2011 07:32 AM
AlaeddineSaadaoui
I am using SQlServer database with ARCSDE 10 and I am wondering if I could set the OBJECTID field of my tables as an identity to be able to auto increment it when inserting data by using SQL queries.
Thank you in advance.
Alaeddine Saadaoui.
saadaoui@marshall.edu
JakeSkinner
Esri Esteemed Contributor
Hi Alaeddine,
Currently, ArcSDE doesn't support columns with identity property set to True. Tables/Feature classes with this property cannot be edited in ArcMap or registered as versioned.
When attempting to create non-versioned edits in ArcMap you will receive an error similar to:
"Database Row Change: An unexpected failure occured.
Underlying DBMS error[Microsoft sql server Native Client 10.0: Cannot insert explicit value for identity column in table 'tableName' when IDENTITY_INSERT is set to OFF.][..tableName]."
NataliyaLys
Occasional Contributor II
Jake,
Do you know if the most recent version of ArcSDE supports column with IDENTIFY properties? I was just trying to set it up, and when I tried to edit my data in ArcMap I got the same error that you were talking about four years ago .
Thank you,
Nataliya
JakeSkinner
Hi Nataliya,
Unfortunately, this is still not supported.
NataliyaLys
Thank you Jake. Is there any other way to auto-generate sequential number in a feature class, without setting "IDENTIFY" property on the column through SQL?
JakeSkinner
Take a look at the Water Utility Network Editing solution.  Included with this is the attribute assistant add-in.  Below is a good help link that walks you through the different methods the add-in provides:
Overview - Attribute Assistant | ArcGIS Solutions
For example, take a look at the autonumber method:
Attribute Assistant methods - Attribute Assistant | ArcGIS Solutions
NataliyaLys
That will only work for the ArcGIS Desktop? Correct? I am trying to get it to work for a feature service that is edited through the Collector app. Thanks, again.
RebeccaStrauch__GISP
Nataliya, you may want to branch or create a new question in Collector for ArcGIS  That will help to get it to people that know Collector more, (Which still might be Jake)
VenusScott
Occasional Contributor III
I'm needing it in Web AppBuilder editing!
Web AppBuilder for ArcGIS
ColeAndrews
Ditto Venus Scott​, we need as well
