Jamal432@gmail.com
(Again) Permanent relocation the fields in the attribute table,
Discussion created by Jamal432@gmail.com on Jan 29, 2012
Latest reply on Aug 24, 2012 by graeme
I�??m not sure if there is a tool that can presentably keep the new position of the fields as we change them from one place to another
For example, in the attached screenshot, if I need to permanently move the filed named �??Community_Eglish�?� to the indicated position, then which tool I can use?
[ATTACH=CONFIG]11505[/ATTACH]
Sure, If I move that field to the indicated position (drag and drop), this this would be temporary such that if we re-added the layer then the field will get back to its original position!
I got a help through the forum on how I can �??Sort�?� the records of the attribute table permanently according to certain fields. The tool is �??Sort�?�! NOW, how could the field be moved to a new position permanently?
Thank you in advance,
Regards
Jamal
Outcomes
