Mach-O Linker Error    ld:framework not found ArcGIS
17397
7
04-05-2012 07:08 AM
JerryChapman
After upgrading to V2.2 I'm getting the Mach-O linker error.  I've followed all the steps to upgrade and compared with the MapView Demo settings.
This is the error:
ld: framework not found ArcGIS
Command /Developer/Platforms/iPhoneSimulator.platform/Developer/usr/bin/clang failed with exit code 1
Does this mean the FrameworksSearchPath is not correct?  I followed step 6 to add Framework Search paths - ${HOME}/Library/SDKs/ArcGIS
[ATTACH=CONFIG]13269[/ATTACH]
NimeshJarecha
Great! You got it working! 🙂
Regards,
Nimesh
JerryChapman
I also tried setting up the Framework Search paths like they are in MapView Demo.  Still getting the same error.
[ATTACH=CONFIG]13274[/ATTACH]
NimeshJarecha
Did you update the 'Other Linker Flags' to '-ObjC -all_load -framework ArcGIS'?
Regards,
Nimesh
JerryChapman
Yes, I did.
[ATTACH=CONFIG]13277[/ATTACH]
NimeshJarecha
Did you follow all the steps outlined in the Migrating existing applications from v2.1?
Please try adding ArcGIS.framework to the project.
Regards,
Nimesh
JerryChapman
Hi Nimesh,
I added ArcGIS.Framework and no change.  So I removed it.
I reinstalled AGSRuntimeSDKiOSv2.2, went into Xcode, loaded my project, compiled, and the linker error is gone.
Everything works.
Jerry
NimeshJarecha
Regards,
Nimesh
GaryThorne
i am having same  problem and unable to solve the issue
