annekull
Landuse polygons to polylines with Left_Poly and Right_Poly attributes
Discussion created by annekull on Apr 14, 2012
Latest reply on Apr 16, 2012 by annekull
Hi!
I have landuse map with polygons (each polygon has landuse attributes). I need a map with polylines describing LEFT_POLY and RIGHT_POLY. And the polylines should be splitted in intersection point of different land use types. And the polylines should not be duplicated. And the polyline must have attribute value corresponding to the left side and right side land use. I attached the figure describing the original land use layer and resulting layer and attribute table.
I can use ArcGIS 10 (ArcInfo). Can you suggest anything that may help to produce the recuired type of map?
Thank you in advance,
Anne
Outcomes
