Visualize Lidar in Arc view
Discussion created by jp_quebec on Apr 27, 2012
i'm using two raster dataset to visualize the geomorphology of a valley: a ground elevation (ge) dataset and a hill shade date set (see picture). The resolution is 1 meter square and the total lidar cover around 4 km square. I want to use Arc view to change the point of view on the lidar and be able eventually to draw upon it to illustrate different scenario of evolution. Is it possible to input the lidar in Arc view with each pixel keeping its own ground elevation and hill shade information?
I tried converting the ge dataset into a Tin , but it losses a lot of resolution. I would like to be able to move in my lidar keeping the same high quality.
Any help? [ATTACH=CONFIG]13887[/ATTACH]
