rickag
Geographic Coordinate System Warning Issue
Discussion created by rickag on May 3, 2012
Latest reply on Jan 21, 2014 by MKennedy-esristaff
A user has a workstation running XP32 and ArcView 10 concurrent license. When you bring in data with different coordinates the screen that should pop up to allow the user to tell the platform what transformation to use for the data does not come up.
[ATTACH=CONFIG]14084[/ATTACH]
I have tried deleting the normal.mxt in both the ArcMap templates directory and the one located in the ArcCatalog directory that shows up.
After doing the above the warning screen came up once and not after that even if the above steps are repeated - I ensured that the check boxes were not checked preventing the message/option to pop up.
The issue shows up regardless of who is logged into the workstation (administrator / user).
Anyone have an idea of what is possibly causing the issue?
Rick
Outcomes
