ArcGIS Earth Blog
87
68.4K
36
Open | Please consider adding the ability to join tables.When adding SQL data to ArcGIS Earth it would be helpful to be able... by Alena New Contributor III 0 1 | 0 | 1 | |
Open | Creating a new Ground Overlay would be easier if :ArcGIS Earth would auto-detect the aspect ratio of the image used a... by GeoffroyRicher-Lalonde Occasional Contributor II 1 6 | 1 | 6 | |
Open | Hi,We have a script that generates a KML file with a placemark that only have an <address></address> tag (no coordina... by GeoffroyRicher-Lalonde Occasional Contributor II 0 1 | 0 | 1 | |
Open | When you have a lot of placemarks inside a group, it would be helpful to be able to sort them out alphabetically with... by GeoffroyRicher-Lalonde Occasional Contributor II 0 4 | 0 | 4 | |
Open | I'm trying to persuade colleagues to step away from Google Earth Pro and migrate to ArcGIS Earth (for obvious reasons... by MadisonLambert New Contributor II 2 1 | 2 | 1 | |
Open | Drawing a new point, the placemark's <hotSpot> (anchor point) will always be at the bottom center. It makes sense if ... by GeoffroyRicher-Lalonde Occasional Contributor II 0 1 | 0 | 1 | |
Open | KML/KMZ elements that can be seen in the Data tab :won't show up in the Legend tab :It would be useful to have access... by GeoffroyRicher-Lalonde Occasional Contributor II 0 4 | 0 | 4 | |
Open | Hello,When a KML drawing is created, some measurements are automatically calculated. For instance, if a user creates ... by GeoffroyRicher-Lalonde Occasional Contributor II 0 1 | 0 | 1 | |
Open | Hello,When a user adds a Shapefile, he can use some options to manipulate it (adjust symbology, add labels, configure... by GeoffroyRicher-Lalonde Occasional Contributor II 0 0 | 0 | 0 | |
Open | Users can export their selections from the Attribute table with the Export selected button* :* if the <enableTableDat... by GeoffroyRicher-Lalonde Occasional Contributor II 0 1 | 0 | 1 | |
Open | The Attribute table can be filtered by the extent, and it is a great tool.It would also be great to have an option to... by GeoffroyRicher-Lalonde Occasional Contributor II 0 3 | 0 | 3 | |
Open | When a user adds a service that contains related tables, he won't be able to see the related records using the Attrib... by GeoffroyRicher-Lalonde Occasional Contributor II 1 1 | 1 | 1 | |
Open | The ability to customize the legend on export. If I have several layers in my map, I can't add a legend without it ta... by NWhittaker New Contributor II 1 1 | 1 | 1 | |
Open | It is presently impossible to draw a polygon with holes in ArcGIS Earth. It would be an improvement to be able to do ... by GeoffroyRicher-Lalonde Occasional Contributor II 0 1 | 0 | 1 | |
Under Consideration | Good day:Here is my idea: Please add snapping functionality to ArcGIS Earth. This should be a basic requirement when ... by BryanAustin New Contributor II 2 2 | 2 | 2 |
Idea Submission Guidelines
