ArcGIS Experience Builder Blog
324
3.9M
80
Open | I have recently implemented including a Image Tile Layer in an ArcGIS Online Experience and I was hoping that like in... by BrianShaw13 New Contributor II 1 0 | 1 | 0 | |
Open | Hi, There doesn't sem to be a way to reconfigure the date field in a line chart to follow the monhs. The first point ... by cat206 Occasional Contributor 3 0 | 3 | 0 | |
Open | At the moment some of the date filters within Experience Builder are limited to AGOL Hosted Feature Services (see bot... by DebSF New Contributor II 1 0 | 1 | 0 | |
Open | When setting up the the Query widget in the Web App Builder (WAB), I was able to add the query results to the layer l... by DJB New Contributor III 0 0 | 0 | 0 | |
Open | At present one of the only map widget functions that you can't add as a separate widget seems to be the measurement t... by LIZDean New Contributor II 1 1 | 1 | 1 | |
Open | I would like the option to have one Value Label on a stacked bar chart that is a sum of all the values that are stack... by NicoleStephan New Contributor II 2 0 | 2 | 0 | |
Open | To be able to have custom font choices in the layers widget. To enable users to choose the font size, type, and color... by edward33 New Contributor III 2 0 | 2 | 0 | |
Open | Hello everyone!I'm a writer. And I'm using EB to tell the story of the Great Wave North, where I use existing climate... by AndrewLechner New Contributor II 0 0 | 0 | 0 | |
Open | When using the search widget to search for a coordinate or a feature name, it displays a town name despite only havin... by SarahBarks New Contributor II 5 0 | 5 | 0 | |
Open | Hi Team, We are looking to limit our users ability to rotate within the map widget on one of our applications. We hav... by EmilyMc New Contributor III 2 1 | 2 | 1 | |
Open | Hi Team, We have several applications that use the Filter or Query widget with a date selector.We would like to propo... by EmilyMc New Contributor III 5 1 | 5 | 1 | |
Under Consideration | Add to the elevation profile widget a way to show what the slope/ grade is at a specific point on your line feature (... by edward33 New Contributor III 7 3 | 7 | 3 | |
Open | I think providing an option within the Map Layers Widget in Experience Builder that would automatically show the laye... by CMcDonald Occasional Contributor II 6 1 | 6 | 1 | |
Open | Right now when you use the "Clear Selection" tool on the List Widget or otherwise clear your selection, there is not ... by GJW New Contributor III 6 1 | 6 | 1 | |
Open | Hi, We have a dataset which is our holy grail and most of our apps/maps/dashboards are based on, and this datasets in... by James_Shreeve New Contributor III 2 0 | 2 | 0 |
Idea Submission Guidelines
User | Count |
15 | |
13 | |
13 | |
11 | |
9 |
