ArcGIS Experience Builder Blog
321
3.8M
79
Open | In Enterprise 11.1, the search widget in Experience Builder can only flash a result from one layer (and only one fiel... by JeffLegato1 Occasional Contributor 4 1 | 4 | 1 | |
Open | I would like the option to have one Value Label on a stacked bar chart that is a sum of all the values that are stack... by NicoleStephan New Contributor II 0 0 | 0 | 0 | |
Open | We are running ArcGIS Enterprise version 11.0. I'm working on updating our WAB apps. As I am setting up the Search Wi... by Shauna-RaeBrown Occasional Contributor 0 0 | 0 | 0 | |
Open | In WAB there was an option to allow people to access directions to the Near Me results. I don't see that as an optio... by JenniferLStrang New Contributor II 3 0 | 3 | 0 | |
Open | In many systems we are using the WAB parameter &find to enable users to see the location of a point on the map. With... by ÉmilieLamontagne New Contributor III 2 0 | 2 | 0 | |
Open | In many systems we are using the WAB parameter &find to enable users to see the location of a point on the map. With... by ÉmilieLamontagne New Contributor III 1 0 | 1 | 0 | |
Open | The WAB draw widget had a Text tool that allowed users to add text anywhere on the map. EB draw tool does not have t... by PriscillaThoopthong New Contributor III 9 2 | 9 | 2 | |
Open | When you complete a query in an experience builder application and it shows you the list of results, there doesn't se... by CameronLacelle Occasional Contributor 1 2 | 1 | 2 | |
Open | When configuring the query widget in EB to create an attribute filter, I use the SQL Expression Builder which opens a... by City_ofNorth_Bay New Contributor III 0 0 | 0 | 0 | |
Open | To be able to have custom font choices in the layers widget. To enable users to choose the font size, type, and color... by edward33 New Contributor III 2 0 | 2 | 0 | |
Open | The query widget is a useful way to allow end users to query data based on different attributes of datasets, and allo... by CameronLacelle Occasional Contributor 3 0 | 3 | 0 | |
Open | It will be nice to support M:N relationship in experience builder as it is describe in these questions:Does Experienc... by AnnaHradecká New Contributor III 4 0 | 4 | 0 | |
Open | It is important for us to display related records in Feature info widget same way as it is in pop-up. by AnnaHradecká New Contributor III 7 0 | 7 | 0 | |
Open | Hello everyone!I'm a writer. And I'm using EB to tell the story of the Great Wave North, where I use existing climate... by AndrewLechner New Contributor II 0 0 | 0 | 0 | |
Open | When using the search widget to search for a coordinate or a feature name, it displays a town name despite only havin... by SarahBarks New Contributor II 5 0 | 5 | 0 |
Idea Submission Guidelines
User | Count |
11 | |
11 | |
10 | |
10 | |
9 |
