Hello I'm new here. I search for layers with "esri/widgets/Search".
297
7
04-30-2024 06:59 AM
emreaktas1
  • Merhaba burada yeniyim.
  • Katmanları "esri/widgets/Search" ile arıyorum.
  • Bu widget'ı istediğim konteynere nasıl yerleştirebilirim?
  • Örnek kod aşağıdaki gibidir.
    View.ui.add dosyasında konteyner kimliğini vermeme rağmen kullanamıyorum.
JoelBennett
MVP Regular Contributor
If you want to place the Search widget in a container of your choosing, you should specify the ID of the container (or a reference to the container element) in the container property of the widget's constructor.  In this case, you would also not use view.ui.add.
const searchWidget = new Search({
    view: view,
    container: "myElementID",
    allPlaceholder: "Enter Search Text",
    //etc
JoelBennett
    view: view,
    //etc
emreaktas1
Hello
I run a query by creating a query feature layer.
I have a small problem can you help me?
JoelBennett
Can you describe what problem you're having?
emreaktas1
I can get the results I want with the sample code.
I can see this with console.log.
How can I display this result in a container
emreaktas1
I want to show the result in a container.
JoelBennett
Perhaps this might be what you're trying to do:
let parselname = feature.attributes.adi_soyadi;
document.getElementById("sonuc").innerHTML = "Malik Bilgisi: " + parselname;
emreaktas1
hi @JoelBennett
I hope you are in good mood and health. everything is fine.
I want to serve a json data.
can you help with this?
