ArcGIS Monitor Blog
141
184.6K
49
Open | Hello,This is a really small thing, but I've noticed when navigating through multiple pages of components, such as se... by ChrisTaylor2 New Contributor III 0 2 | 0 | 2 | |
Under Consideration | Hello Team, Since my Monitor deployment 2023.3.1 is currently in the testing phase, I have created around 20 custom c... by Shawn_NG New Contributor II 0 1 | 0 | 1 | |
Under Consideration | Wondering if ArcGIS Monitor can help us find out who created a new or updated an existing map service on either feder... by NiG New Contributor II 0 2 | 0 | 2 | |
Under Consideration | The webhook subscribed events lacks a lot of attribute information when compared to the feature service enabled on th... by EddieFung1 New Contributor III 0 1 | 0 | 1 | |
Under Consideration | Request the capability to query arcgis monitor to get metric of the current portal roles that are enabled/assigned to... by Pat_Gallagher New Contributor III 7 1 | 7 | 1 | |
Under Consideration | It would be really nice to see what each ArcGIS Servers log level is set to and when someone changes the log level. by SteveMcCarthy Occasional Contributor 4 1 | 4 | 1 | |
Under Consideration | If it was possible to see the layers within each map service within monitor that would be excellent. I have used oth... by ChrisBerryman New Contributor III 4 4 | 4 | 4 | |
Under Consideration | Hi,I have installed and configured the ArcGIS monitor 2023.3.1. After that, create a dashboard by following this - ht... by AYUSHYADAV New Contributor III 0 3 | 0 | 3 | |
Under Consideration | Hi - Would it be possible to have access to the arcgisdatastore.exe process for ArcGIS Monitor 2023 and beyond? It's ... by DavidColey Frequent Contributor 2 1 | 2 | 1 | |
Under Consideration | Hi - is it in the Monitor road map to include a a process metric for the w3wp.exe instances/counts? I use this in Mo... by DavidColey Frequent Contributor 0 5 | 0 | 5 | |
Under Consideration | We have the donut chart but it would also be useful to be able to add a table chart as well - while this displays the... by FraserHand Occasional Contributor III 1 1 | 1 | 1 | |
Under Consideration | Can you please add the Name field to the alerts? The metric Id is unique to each metric, so there is not an easy way... by KevinS New Contributor III 2 3 | 2 | 3 | |
Under Consideration | In a large IT environment, it should be possible to fully automate both the installation and configuration of softwar... by Tobias_Gerber New Contributor III 7 7 | 7 | 7 | |
Under Consideration | When I click on an alert link in email, I am redirected to the browser which opens up to Monitor. If I haven't used ... by JamesBratton Occasional Contributor 2 1 | 2 | 1 | |
In Product Plan | Would love to be able to monitor the total number of open sessions to a database. It would help to monitor overall lo... by TimoT New Contributor III 3 1 | 3 | 1 |
Idea Submission Guidelines
User | Count |
2 | |
2 | |
1 | |
1 | |
1 |
