Reset error messages in Connect after each reload
148
04-19-2024 12:28 PM
Status: Open
abureaux
MVP Regular Contributor
Currently in Connect, when something results in an Error, the error message persists between reloads.
That means that even if you correct the error, the error message remains until you manually press "OK".
This can create confusion when an error is resolved, but the error message was not cleared prior to the most recent reload of Connect.
Instead, error messages should be cleared when Connect reloads so that any visible error message is relevant to the current state of the survey.
1 Comment
RobertAnderson3
This drives me nuts, this absolutely needs to be remedied.
