How join two survey123's with different subjects but with the same feature layer or feature service?
For example, I have an S123 that gather information about trees, like common name, family, species, diameter of trunk, height, location, etc.
Now I need to create an S123 to identify the owner of the land and some physical characteristics of the property, like legal status, public deed of the property, soil type, access to property, drawings, topography, etc.
The obvious solution is to create a long S123 with several questions on both topics but using multiple "relevant" options to display the desired questionnaire. To me, this is an inefficient way to capture field data because the personnel that capture tree information will leave all property questions empty, the opposite is true.
Can I use for example, in a S123 settings tab the submission URL column on both S123 with the same address (if two S123 can be created this way)?
Or there is another way to do this using ArcGIS Pro to create all parameters required, and then create several S123s depending on the subject?
