Developers Ideas
Developers Ideas
Other Boards in This Place
Latest Activity (370 Idea Submissions)
Sort/Filter :
Open
Hello, I am just getting started learning Arcade and I am trying to utilize the ArcGIS Arcade Playground on developer...
AmberMillison
by AmberMillison New Contributor III
in Developers Ideas Last Updated 03-26-2024
0 1
Open
Allow API to set distance from the given location within which a matching address should be searched. We are currentl...
rverdone
by rverdone New Contributor II
in Developers Ideas Last Updated 03-13-2024
0 0
Open
Following up on this question (CodeTaskFactory not included in .NET Core) it would be great to use `dotnet build` in ...
StephenRhea_NV5
by StephenRhea_NV5 Occasional Contributor
in Developers Ideas Last Updated 12-14-2023
1 0
Open
Directory Refresh when pulling in .SVG files so no need to close and restart ArcGIS ProWhen adding new icons (.SVG fi...
ScottFoulk
by ScottFoulk New Contributor II
in Developers Ideas Last Updated 10-19-2023
2 0
Open
When a developer builds a server side application, and uses ArcGIS Identity/OAuth 2.0 authentication (https://develop...
RuslanRydvanskiy
by RuslanRydvanskiy New Contributor II
in Developers Ideas Last Updated 08-09-2023
0 0
Open
Falta la comunidad de ArcGIS Enterprise SDK@Raul_Jimenez , a quien agradezco, me sugirió que lo plantee como Idea  ba...
AnibalMmartinez
by AnibalMmartinez Occasional Contributor
in Developers Ideas Last Updated 07-31-2023
0 0
Open
I wish for an app that displays the ArcGIS Online map, but without the possibility of other people editing it.So kind...
LindMill
by LindMill New Contributor III
in Developers Ideas Last Updated 06-22-2023
0 0
Under Consideration
Hi Esri,Nearly all SDKs have their own board in the "Developers" board. However, the "Enterprise SDK" does not.Curren...
RalfSchmidt
by RalfSchmidt New Contributor III
in Developers Ideas Last Updated 03-17-2023
0 1
Under Consideration
On the ArcGIS Developers site, you can click the View Usage button on any Geocoding API you have created. For the tim...
DavidWittmann
by DavidWittmann New Contributor III
in Developers Ideas Last Updated 03-20-2023
0 1
Already Offered
On the ArcGIS Developers site, you can click the View Usage button on any Geocoding API you have created. By default ...
DavidWittmann
0 1
Open
When getting a single extent, the polygon property returns the object as a multipolygon rather than a polygon.  Exten...
EricEagle
by EricEagle Occasional Contributor III
in Developers Ideas Last Updated 01-09-2023
3 0
Open
INSPIRE metadata can be imported manually in ArcGIS Pro, but using arcpy this is not an option. Adding INSPIRE metada...
NseaGIS
by NseaGIS New Contributor II
in Developers Ideas Last Updated 01-02-2023
2 0
Open
When a Parameter holds multiple values, it would be nice to be able to catch them in a simple list object instead of ...
EricEagle
in Developers Ideas Last Updated 12-30-2022
3 1
Open
In AGOL and Portal, I have a point featurelayer for inspection points related (1 to Many) with a inspecctions table, ...
PedroSantos2
by PedroSantos2 New Contributor II
in Developers Ideas Last Updated 12-11-2023
3 1
Open
In ArcMap you are able to use the Identify tool to draw a box around multiple Address Points or other multi-features ...
MarissaNowakowski
by MarissaNowakowski New Contributor
in Developers Ideas Last Updated 07-21-2022
0 2
106 Subscribers
Idea Submission Guidelines
We love hearing from you about how to improve our products. To learn how to submit a valid idea, please review the Submission Guidelines
