POST | I made a custom widget that executes a query and then sends the response to this method in widget.tsx: const populat... by Esprit3 New Contributor II 1 0 | 1 | 0 | 172 | |
POST | How would I go about sending a response from a query from a custom widget to the table widget dynamically? by Esprit3 New Contributor II 0 0 | 0 | 0 | 134 | |
POST | So, I have a custom widget, where the user can select a layer from a map. From there he can choose a field, an operat... by Esprit3 New Contributor II 1 0 | 1 | 0 | 144 | |
POST | Does anyone know how we should be sharing third party libraries across multiple widgets?I have read some documentatio... by PartyPelican New Contributor III 1 3 | 1 | 3 | 192 | |
POST | Hello,Robert wrote a code snippet that tweaked one of the Web Appbuilder Developer Edition source files so that inter... by BrandonPrice1 Occasional Contributor 0 0 | 0 | 0 | 99 | |
POST | Hi,I have been using the Select component from jimu-ui (https://developers.arcgis.com/experience-builder/storybook/?p... by clc New Contributor III 0 2 | 0 | 2 | 142 | |
POST | Hello,Does anyone know if there is a way in experience builder developer edition to query related records from a data... by PartyPelican New Contributor III 0 1 | 0 | 1 | 160 | |
POST | I adapted arcgis-map widget to make it one of my custom widgets.In the development ide, in arcgis-map "Content" tab (... by MichaelLev Occasional Contributor III 0 1 | 0 | 1 | 150 | |
POST | I adapted arcgis-map widget to make it one of my custom widgets.In src/runtime/componnts/mapbase.tsxI want to use src... by MichaelLev Occasional Contributor III 0 0 | 0 | 0 | 192 | |
POST | Hello! I am trying to use code sharing in my project (https://developers.arcgis.com/experience-builder/guide/share-co... by majae New Contributor 0 0 | 0 | 0 | 131 | |
POST | Hi, everyone I created a custom EB widget and deployed it successfully. I made some changes on the sorce code and I... by GerganaZlateva New Contributor 0 1 | 0 | 1 | 176 | |
POST | All, I'm a newbie - Be nice!Is it possible to create a buffer widget and have the resulting buffer able to export to ... by mkauth_wardgetz New Contributor II 0 0 | 0 | 0 | 181 | |
POST | Hello Community , I am new to experience builder and i am currently working on a demo .I would want to know if a text... by KwabenaDenteh1 New Contributor II 0 1 | 0 | 1 | 209 | |
POST | Hello all,I hosting arcgis experience builder apps on an azure web app service. I have a custom widget that requires ... by RoderickPerendy New Contributor III 0 2 | 0 | 2 | 298 | |
POST | I have an application that has filter widgets that interacts with the map on the page. The client would now like to b... by RezaTehranifar2 New Contributor III 0 4 | 0 | 4 | 351 |
User | Count |
9 | |
4 | |
2 | |
1 | |
1 | |
1 | |
1 | |
1 | |
1 | |
1 |
