File Geodatabase API Blog
75
148K
POST | Is there a way to create a standalone table in a FGDB using the file geodatabase API?If yes, does the table get autom... by Bud Notable Contributor 0 1 | 0 | 1 | 476 | |
POST | Does anybody have a sample in C# that create a GDB, create a feature class in it and add a point to this feature clas... by mody_buchbinder Occasional Contributor III 0 3 | 0 | 3 | 813 | |
POST | I'm trying to read some of the geodatabase-level metadata from the GDB using the FGDB API.I know how to do this for t... by TimStone New Contributor II 1 0 | 1 | 0 | 504 | |
POST | Hai, i want to read blobs field data size from my filegdb by fileGDBAPI with C++, But i always get NULL Binary data... by LiuYingying New Contributor 0 0 | 0 | 0 | 480 | |
POST | Hi there,I want to import a FGDB into a Xamarin forms application, but I can't find an easy way to do it. I simply wa... by SaghiKhani New Contributor 0 0 | 0 | 0 | 590 | |
POST | i have succesfuly queried for a single envelope and returned the parcel data in geojson.https://services1.arcgis.com/... by Tman New Contributor 0 0 | 0 | 0 | 531 | |
POST | We have some customers and partners still relying on the File Geodatabase API. Currently, they try to migrate or at l... by Jan-Tschada Esri Contributor 2 2 | 2 | 2 | 837 | |
POST | Regarding the docs: SQL for reporting and analysis on file geodatabasesWhat parts of ArcGIS does the syntax in that p... by Bud Notable Contributor 0 1 | 0 | 1 | 820 | |
POST | Is there documentation that outlines what functionality was released at each FGDB version, and when?Fake examples:Ver... by Bud Notable Contributor 0 0 | 0 | 0 | 593 | |
POST | 0 | 1 | 722 | ||
POST | I have configured the FileGDB API with Visual Studio 2019, and I can read the data in the geodatabase. But I want to ... by HuYuChen New Contributor 0 0 | 0 | 0 | 648 | |
POST | Is it possible to create feature layer from C# controller as and when we get new data to the application from front e... by SurajKore New Contributor 0 0 | 0 | 0 | 779 | |
POST | Hello,I wonder, how I can create a Polygon-Featureclass with the two standard-columns SHAPE_Length and SHAPE_Area. Mu... by TOPOGRAPHICS New Contributor II 0 1 | 0 | 1 | 869 | |
POST | hi,i get the following error in fme Geodatabase Error (-2147220987): The user does not have permission to execute the... by GISDG New Contributor 0 1 | 0 | 1 | 1318 | |
POST | 0 | 0 | 739 |
