Store URLs from a field into a list using arcpy
136
04-30-2024 08:41 AM
Ed_
by MVP Regular Contributor
  • I am trying to read a geodatabase table into a script.
  • Store URLs from Item_URL field into a list
Stuck ok step 2, how can I fix this?
import arcpy
import pandas as pd
from datetime import datetime, timezone
import pandas
import urllib
import http
import sys
# Import the geodatabase table
ItemsURL = "O:\\CheckURLs\\MyProject.gdb\\HubitemCatalogList"
# Select the fields to print
fields =  ['Item_URL']
with arcpy.da.SearchCursor(ItemsURL, fields) as cursor:
    for i in range(5):
        for row in cursor:
            print(row)
            break
    print('Geodatabase table was read in just fine :)')
# Create a list of URLs from Item_URL field
URL_List = []
URL_List = ItemsURL['Item_URL']
Print('List created successfully')
Error:
TypeError: string indices must be integers
Question | Analyze | Visualize
AlfredBaldenweck
Right now, you're asking it to return an index from the string
So like, ItemsURL[0] would return"O". This is not what you're trying to do.
Try this instead?
 Basically, bring the URL_List up and then append each value into it as you iterate over the rows.
import arcpy
import pandas as pd
import pandas
import urllib
import http
import sys
URL_List = []
    for i in range(5):
        for row in cursor:
            print(row)
            # Add the Item_URL value to the list.
            URL_List.append(row[0])
            break
print('List created successfully')
print(URL_List)
AlfredBaldenweck
Try this instead?
import arcpy
import pandas as pd
import pandas
import urllib
import http
import sys
URL_List = []
    for i in range(5):
        for row in cursor:
            print(row)
            break
print(URL_List)
