Error while apply asset package CommunicationsUtilityNetworkFoundationV1_1
403
03-18-2024 03:22 AM
RajAlva00
Hello Community Members,
While applying the asset package on CommunicationsUtilityNetworkFoundationV1_1, I am getting the following error. The previous stage of the utility network geoprocessing run was successful.
I am using the ArcGIS enterprise 10.9.1 version ,
Asset package  : CommunicationsUtilityNetworkFoundationV1_1
ArcGIS Pro:  2.9.10
Python package Untools: 2.9.7
Can anyone highlight what might be the issue here?
AlbaraA
New Contributor II
 @RajAlva00  I have created another Py clone, and restarted ArcGIS (pro 3.1), and I found the Asset Package loaded into the Utility Network, despites all the error I got earlier.
Apparently, rebuilding the Py environment solves it.
Thank you @SpatialNinja
SpatialNinja
@RajAlva00
Have you tried to re-build your python environment clone?
Can you attempt again without any maps open in the project?
Have you also put in a support ticket?
Solutions Engineer | Spatial Ninja  | GIS ️ | Telecommunications
AlbaraA
New Contributor II
@RajAlva00  Was it resolved? I've been into the same error (well.. and thousands others). I tried closing the maps but didn't help, I wonder if you tried to rebuild the Py environment.
Once I get to the same error again I'll reply with any updates I get.
AlbaraA
New Contributor II
