I looked into this and I've narrowed down the problem. I think the parameters somehow get mangled when inputted into the tool by gp_fixargs.
Here's a very basic python tool to test this issue:
# -*- coding: utf-8 -*-
import arcpy
import os
import traceback
from pathlib import Path
class Toolbox(object):
def __init__(self):
self.label = "Toolbox"
self.alias = "toolbox"
# List of tool classes associated with this toolbox
self.tools = [Tool]
class Tool(object):
def __init__(self):
self.label = "Tool"
self.description = ""
self.canRunInBackground = False
def getParameterInfo(self):
params = [
arcpy.Parameter(
displayName="Input file",
name="input_file",
direction="Input",
parameterType="Required",
datatype="DEFile"
return params
def isLicensed(self):
return True
def updateParameters(self, parameters):
return
def updateMessages(self, parameters):
return
def execute(self, parameters, messages):
ext_status = arcpy.CheckExtension("DataInteroperability")
if ext_status != "Available":
arcpy.AddError(f"Data Interoperability status: {ext_status}")
else:
arcpy.AddMessage("Data interoperability available")
arcpy.CheckOutExtension("DataInteroperability")
kmlPath = parameters[0].valueAsText
arcpy.AddMessage(f"Input file: {kmlPath}")
if not os.path.exists(kmlPath):
arcpy.AddMessage("Source file doesn't exist")
return
arcpy.AddMessage("File contents:")
with open(kmlPath, 'r') as file:
for row in file.readlines():
arcpy.AddMessage(row)
arcpy.AddMessage("")
output_dir = arcpy.env.scratchFolder
if not os.path.exists(output_dir):
arcpy.AddMessage("Creating destination folder")
Path(output_dir).mkdir(parents=True, exist_ok=True)
output_gdb = os.path.join(output_dir, "export.gdb")
arcpy.AddMessage(f"Output gdb: {output_gdb}")
try:
res = arcpy.interop.QuickImport(
Input=kmlPath,
Output=output_gdb
arcpy.AddMessage(str(res))
except Exception as e:
arcpy.AddMessage(traceback.format_exc())
def postExecute(self, parameters):
return
And here's a very simple test file to reproduce the error with (test.geojson):
"type": "Feature",
"geometry": {
"type": "Point",
"coordinates": [125.6, 10.1]
"properties": {
"name": "Dinagat Islands"
Parameters used to publish webtool:
Messages when running locally:
Input file: C:\Users\_____\_____\Documents\ArcGIS\Projects\QuickImport\test.geojson
File contents:
"type": "Feature",
"geometry": {
"type": "Point",
"properties": {
Output gdb: C:\Users\_____\_____\Documents\ArcGIS\Projects\QuickImport\scratch\export.gdb
Messages when running published as Web Tool:
Input file: D:\arcgisserver\directories\arcgisjobs\quickimporttesttool_gpserver\ja6af2726b46a455296ce7e438a7d2492\scratch\test.geojson
File contents:
"type": "Feature",
"geometry": {
"type": "Point",
"properties": {
Output gdb: D:\arcgisserver\directories\arcgisjobs\quickimporttesttool_gpserver\ja6af2726b46a455296ce7e438a7d2492\scratch\export.gdb
File "<string>", line 84, in execute
File "d:\arcgis\server\framework\runtime\arcgis\Resources\arcpy\arcpy\interop.py", line 103, in QuickImport
raise e
File "d:\arcgis\server\framework\runtime\arcgis\Resources\arcpy\arcpy\interop.py", line 100, in QuickImport
retval = convertArcObjectToPythonObject(gp.QuickImport_interop(*gp_fixargs((Input, Output), True)))
File "d:\arcgis\server\framework\runtime\arcgis\Resources\arcpy\arcpy\geoprocessing\_base.py", line 511, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
Failed to execute (QuickImport).
