Windows Task Scheduler Error
382
12-06-2023 11:14 AM
AshleyHayes2
New Contributor III
When I run Data Interoperability via Windows Task Scheduler, I receive an "ERROR : Python Exception <ExecuteError>: ERROR 160236: The operation is not supported by this implementation. Failed to execute (DeleteRows)." from my shutdown script.
When I run it manually in ArcPro, I do not receive any errors and everything works as expected.
Any suggestions?
Also, @BruceHarold -- is there a way to subscribe to your "What's New in ArcGIS Data Interoperability" blog posts?
Thank you!!
BruceHarold
Hello Ashley
It seems you have struck an issue we haven't found a cause for:
https://pro.arcgis.com/en/pro-app/latest/tool-reference/tool-errors-and-warnings/160001-170000/tool-...
If you open a support call the analyst can look at your workflow.
Re. subscribing, if you subscribe to the whole Data Interoperability board you'll get everything, and thank you for asking.
A_Baker_
Hi Ashley,
Were you able to resolve this issue? I have been intermittently encountering the same error while running scripts through Task Scheduler and have been unable to determine the cause or a fix.
Thank you!
xandermavrides
Any luck?
