Hello RJ Sunderman,
Hope you are doing great.
We are working on 10.3.1 for configuring SMS Output for a Telecom Client in Kuwait. Based on the above answer, I understand that we will require the following details:
1. Specific carrier name (Eg. AT&T, Altel)
2. SMS Gateway which should be used (Eg. @txt.att.net, @message.alltel.com)
3. SMTP server host name or IP address
4. SMTP server port number
5. SMTP authentication mode
After my discussion with the client, they mentioned that they can provide "SMPP" configuration. Could you please let us know whether we can configure SMS Output using SMPP configuration?
Thanks a lot.
Regards,
Richardson
