Hello, Our product is using StreamLayer with a vast amount of updates, that are sent through "sendMessageToClient" API.
After ±20 minutes of use, the map becomes blank, and a large amount of errors such as :
TypeError: Cannot read properties of undefined (reading 'memoryStats')
at get memoryStats
And: Array buffer allocation failed
are popping up. so the map gets stuck and hundreds of errors are stacked.
We verified that it only happens on 4.29, downgrade to 4.28 resolves this.
Pretty tough for me to reproduce this on a sandbox because of the nature of the data and update amount.
If this can be fixed before 4.30 it would be very helpful.
Thanks.
