Full-Text Search on Arcgis SDK JS
239
a month ago
fb1
New Contributor III
good morning,
is there a possibility to have a full-text search in the Search widget?
Current behaviour:
if i search only 'sud' 'est' or 'nord' can find nothing
MichaelSnook
Occasional Contributor III
In the properties for each SearchSource item that you have referenced in your Search Widget, add the 'prefix' and 'suffix' properties as needed with a wildcard '%'.
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Search-SearchSource.html
MichaelSnook
fb1
New Contributor III
thank you!! it worked perfectly
RussRoberts
Esri Notable Contributor
If you are using a hosted feature layer in Online you can add a full text index on the service through the layer settings and then search will leverage that index if it exists
https://doc.arcgis.com/en/arcgis-online/manage-data/manage-hosted-feature-layers.htm#ESRI_SECTION1_0...
