Cannot export model to graphic (pdf or svg) in ArcGIS Pro 3.2 ModelBuilder.
252
4 weeks ago
HollyBrackett
I edit the model from the toolbox.  In the ModelBuilder tab, I select Export > Export to graphic which opens the Export Image dialog.  I navigate to the folder I want to place the file in and choose one of the formats, either SVG or PDF.
If I choose the pdf option, the pdf document is created but when I open it, there is an error message stating "There was an error opening this document.  This file cannot be opened because it has no pages."
If I choose the svg option, the tool closes and a file is not created.  (Yesterday, the pdf error occurred and I tried the svg format and it worked fine.  Then today, the pdf and the svg do not work.)
