In the ArcObjects SDK there is a method called QueryPointsAndDistances, which is a member of the ICurve3 Interface. Can you please add support for this in the ArcGIS Pro SDK as part of the IGeometryEngine Interface under the ArcGIS.Core.Geometry namespace? This functionality would be really useful for my linear referencing work. Please note: this method is not to be confused with the QueryPointAndDistance method, which is already available in the Pro SDK but only returns a single map point and does not provide an enumerator returned from QueryPointsAndDistances available in ArcObjects. Thank you!
We will add it in the next release. Thank you for the suggestion.
Annette
