Public Transit Questions
58
726K
134
POST | Hi All,I am trying to create recreate a transit network for my city using the GTFS data through the GTFS to Public Tr... by JuanVilla12 New Contributor II 0 5 | 0 | 5 | 144 | |
POST | Hello, I'm getting "ERROR 000354: The name contains invalid characters" at line 59 of the attached python script, at ... by JosephAhrenholtz1 New Contributor II 0 9 | 0 | 9 | 625 | |
POST | Hi, I have created a Public Transit Network Dataset out of OSM-street data and official gtfs-data. It mostly works, b... by RavenSchmidt New Contributor III 0 4 | 0 | 4 | 605 | |
POST | I have two sets of network datasets: (1) a road network and (2) a walking and cycling network.To create a GTFS transi... by TackGuanLau New Contributor 0 1 | 0 | 1 | 714 | |
POST | I have no idea if this is possible, but thought it was worth asking in an effort to avoid manual work.I'm accessing T... by KD_ New Contributor II 0 5 | 0 | 5 | 925 | |
POST | Hello. I'm struggling to run the Calculate Accessibility Matrix tool for a metro region, following this workflow: ht... by JosephAhrenholtz1 New Contributor II 0 7 | 0 | 7 | 1621 | |
POST | I am trying to calculate the mean travel time from a set of origins to a set of destinations over a time window and d... by BenKlar New Contributor 0 1 | 0 | 1 | 569 | |
POST | Hello,After I loaded my GTFS data on ArcGisPro, i've deployed my GTFS's shapes with this tool:https://pro.arcgis.com/... by NATHANMARYCAMPION New Contributor II 0 6 | 0 | 6 | 1472 | |
POST | Hi @MelindaMorang , I am trying to get the output that was available in the older tools in ArcMap now in Pro. The cal... by PhillipCarleton New Contributor II 0 6 | 0 | 6 | 1281 | |
POST | Hello,I am having an issue with the Calculate Accessibility Matrix tool from the Transit Network Analysis toolset. I ... by JosephGarcia New Contributor II 0 11 | 0 | 11 | 3563 | |
POST | Hi folks,Just found the Transit Network Analysis tools. Fantastic job, they are awesome.I'm really hoping to use the ... by MichaelVernon New Contributor 0 10 | 0 | 10 | 1927 | |
POST | Hello, I received the above error message when I tried to use this tool. I don't think it's an issue with my GTFS dat... by WendyNgan New Contributor 0 2 | 0 | 2 | 852 | |
POST | Hi there,I am trying to use the Copy Traversed Source Features tool to look more closely at the routes being generate... by MM111 New Contributor III 0 7 | 0 | 7 | 1370 | |
POST | The length and shape of the line feature aren't used by the Public Transit evaluator to calculate the travel time. Wh... by Allenlai New Contributor 0 2 | 0 | 2 | 1057 | |
POST | Hi there, I followed the tutorial to create a NDS from a GTFS-Source. If I now solve a routing problem through a rout... by phunky New Contributor 0 8 | 0 | 8 | 1508 |
