POST | Camera focused using map extent (4 co ordinates min – max X and min – max Y).My Code:self.map.maxExtent = Envelope(xM... by JyoshnaRani New Contributor II 0 3 | 0 | 3 | 167 | |
POST | The only way to access the popups for a feature (that I am aware of) is using the identify method, which will only ac... by Justin_Greco Occasional Contributor II 0 2 | 0 | 2 | 110 | |
POST | Hi,I want to implement a heat map with AGSArcGISTiledLayer but I could not find any document. My mobile application d... by mohdarshad New Contributor 0 1 | 0 | 1 | 153 | |
POST | I have an Webmap for which I have created a couple of preplanned offline areas and when I try to load the offline map... by manishfueled New Contributor 0 1 | 0 | 1 | 163 | |
POST | Hello,I am trying to add Shapefile to the ArcGis map creating a Feature layer. But SDK always gives me an error sayin... by ShrutiVaman New Contributor II 0 11 | 0 | 11 | 447 | |
POST | Hello everybody,we currently have the issue that we have to avoid the use of safari services. Our goal is to use the ... by mmoosbac94 New Contributor 0 7 | 0 | 7 | 371 | |
POST | I have a iOS app that using swift maps SDK to show the map. The popup for the feature is showing all the normal field... by DRae New Contributor III 0 2 | 0 | 2 | 163 | |
POST | There exists a very useful way to debug requests in 100.x, this:let config = AGSRequestConfiguration.global() config.... by zdtorok New Contributor II 0 1 | 0 | 1 | 269 | |
POST | Hi, all,I am brand new to SwiftUI and in the process of converting an app built in AppBuilder to a native Swift app.U... by smithse New Contributor III 0 2 | 0 | 2 | 311 | |
POST | I would like to present arcgis.com's Sign in screen to authenticate users. So they can use SAML logins. I'm using a... by DuanePfeiffer New Contributor III 0 4 | 0 | 4 | 421 | |
POST | I have a view that uses tab tab for iPhone layout (aka. "compact" size class) and a full-screen map with a floating o... by sveinhal New Contributor II 0 4 | 0 | 4 | 413 | |
POST | Hello, I would like to know if there is an equivalent of the worldview parameter in the swift SDK.If not, is there an... by EssaddekMohammed New Contributor II 1 3 | 1 | 3 | 314 | |
POST | I am experiencing a strange error when opening a just-downloaded .mmpk. It only happens on the first download of the... by DuanePfeiffer New Contributor III 0 3 | 0 | 3 | 275 | |
POST | I'm using .onDrawStatusChanged to observe when the map is loading and not. While the status is .inProgress, I'm showi... by sveinhal New Contributor II 0 7 | 0 | 7 | 525 | |
POST | I'm consistently getting crashes in the map renderer on my iOS app. I can pretty consistently get it to crash by eit... by dmc76 New Contributor III 0 8 | 0 | 8 | 602 |
User | Count |
14 | |
4 | |
4 | |
2 | |
1 | |
1 |
