3D Questions
77
4.9M
1.5K
POST | Hello, I'm trying to import these Revit files into ArcGIS Pro. They all have unknown coordinate system projections, m... by HGuzman New Contributor II 0 0 | 0 | 0 | 56 | |
POST | I am trying to determine what I might be doing wrong or if anyone else has experienced the geometry issue in the atta... by DJohnsonYYC New Contributor 0 0 | 0 | 0 | 27 | |
POST | I have a 3D bridge that I imported from Bentley Open Roads Designer. This could easily have been Autodesk Civil 3D as... by eric3918esridot New Contributor II 0 0 | 0 | 0 | 104 | |
POST | I have been tasked to determine what trees near an airfield need to be trimmed. (They don't want the trees removed). ... by JonathanDiLella New Contributor 0 0 | 0 | 0 | 45 | |
POST | I'm working with 3D polylines that I've mapped on a 3D model in a local scene. For subsequent analysis, I would like ... by SeanBemis1 New Contributor II 0 4 | 0 | 4 | 149 | |
POST | I'll soon be entering the GIS / data analitics world and want to upgrade my work laptop. My workplace is currently pr... by h1user New Contributor 0 2 | 0 | 2 | 165 | |
POST | Hi,I converted some contour lines to a TIN surface using ArcPro and was hoping to use ArcScene to convert that TIN to... by DanLewCSM New Contributor 0 0 | 0 | 0 | 123 | |
POST | I am trying to find the best way to map a Columbarium.I was thinking of creating a scene with a 3D Object having a ce... by MelissaSalich Occasional Contributor 0 0 | 0 | 0 | 78 | |
POST | I have a very large TIN dataset that I would like to use as a custom elevation source, but it kills the performance o... by k1inmo New Contributor 0 1 | 0 | 1 | 183 | |
POST | I am performing a tree census in the desert that needs to identify, measure (height), and photograph Joshua trees inc... by TonyTG New Contributor 1 1 | 1 | 1 | 178 | |
POST | I hope you are well. Both my colleague and I share a passion for exploring 3D modeling techniques, and recently, we h... by quangdang New Contributor 0 0 | 0 | 0 | 185 | |
POST | Hi all,I wonder if I'm missing something obvious here. I'd like to use the skyline and skyline barrier tools to gener... by RobStauder Occasional Contributor 0 1 | 0 | 1 | 179 | |
POST | I am working on the 3D model of a city. My task is to merge polygons into buildings. However, my polygons are in mult... by MatusKolenka New Contributor 0 0 | 0 | 0 | 312 | |
POST | Could some please advise me on how to get point (Shapefile) labels from floating around all willy nilly and appear as... by SonarBATStructureMAPS New Contributor III 0 0 | 0 | 0 | 502 | |
POST | I published a Web Scene for some Drone2Map content and the "Image Centers" are being truncated in the foreground in t... by JonathanDandois Occasional Contributor 0 0 | 0 | 0 | 270 |
