calculateVolume operation not working well
308
09-12-2023 08:38 AM
BasileNICOLAS1
I am building a widget using ArcGIS REST API v4.
I want to calculate the volume of a selected geometry using the calculateVolume operation (https://developers.arcgis.com/rest/services-reference/enterprise/calculate-volume.htm)
I managed to use the polygon tool to select my geometry of a scene, but when I send the data (the geometry) to the calculateVolume operation, I do not get any good results ; I even get different errors from the same data.
Any test queries or guidance to make the calculateVolume operation work correctly, would be great
RoderickPerendy
I don't have a solution but wanted to state I'm running into the same issue.
