Create a Noise Map on 3D City Model
5575
05-07-2016 07:26 AM
GiuseppeMazzei
Hi ,
I'm an engineering student at the University of Calabria, Italy.
I'm creating a 3d city model with real gis data. I used CityEngine in a first stage.
I should make a noise map in 3d for my thesis but do not know how to do. Some Advice?
I have the shape file of the streets and buildings. The streets Shape include the noise levels.
That interpolation use in ArcMap to show the noise map? How do I represent the noise on facades of the buildings?
How do I create a noise map in 3d ?
Here is some images of the my scene created with CityEngine 2015.213071995_10153023876782168_3494588378664379377_o.jpg13047791_10153023877402168_3314891084468983365_o.jpg
Thank you
MicahTaylor
Occasional Contributor III
This sounds like a cool project.  I also like the look of your model.
Here is a suggestion....
1. Create the area around the streets representing the different levels of noise (possibly with a buffer /  buffers OR a distance raster from the streets)
2. Create a "noise_level" attribute in the building shapes.
3. CityEngine - write CGA attr for and assign the facades a color based on the new noise_level attribute.
for example...
attr noise_level = 1        #connect this to your building shape "noise_level" attribute
noiseLevel = case noise_level == 1 : "#99192A"
                     case noise_level == 2 : "#B23343"
                     else : "#CC4C5D"
#Code to generate buildings
YourFacadeRule-->      #This rule could color facades (or possibly roofs??) based on each buildings noise level
     color(noiseLevel)
OR you could use a noise raster as a map layer type....
Help -
Hope this helps...let me know how it goes.
