How can I add a ruler/calibrated line in arcscene environment?
2441
01-02-2016 11:00 AM
ElijahNjoku
I have pasted a screen shot of raster layers meant to show different contaminant levels at different soil depths, I need to use anything like ruler or calibrated bounding box (showing vertical distance between the layers) to show the height/depth of the different layers. I am yet to disover how this could be done. Also, I will like to understand how I can offset the layers horizontally to enable a better view of each layer/
DanPatterson_Retired
  • please find a better home for your question... the Lounge is for lounging... check this to locate a better home for wayward questions
  • GeoNet Community Structure
  • didn't see an attachment
  • to offset layers, you need the 3D analyst extension and you can offset by a fixed amount and/or from baseheights
