How to create 3D solid geologic model of subsurface
2774
06-14-2010 11:15 AM
MinaRahimi
New Contributor III
My data includes X,Y,Z. I also have the thickness of each geologic layer. I can create TIN of each geologic layer but I don't know how can I fill the gap between these layers.
How can I create 3d solid geologic model in ArcGIS?
Mina
Tags (1)
JakubSisak
Occasional Contributor III
This is normally done by extruding between 2 surfaces which created a multipatch geological layer. You will need 2 TIN surfaces (top surface and bottom surface) and a polygon layer containing input features that defines the area you wish to extrude.
See Toolbox -> 3D Analyst Tools -> TIN Surface -> Extrude Between
MinaRahimi
New Contributor III
What should be the input polygon layer? How can I define the area between surface and bottom tins?
JakubSisak
The Input Polygon layer is basically the 2D (Plan View) Area of interest, or the most outer extent of your model.
Help on "Extrude Between" provides an explanation on this including a figure with visual...
MinaRahimi
New Contributor III
Thanks alot
It works.
Mina
MinaRahimi
New Contributor III
It works but the layers are not correct. The geologic layers that are made by this way do not correspond with the existing map.
I used bedrock geology for the polygon feature. Do you know what should I do?
Thanks
Mina
