LandXML to TIN doesn't work
5169
7
11-08-2011 01:59 PM
Thomastang
Does someone understand why the LandXML to TIN doesn't work? It showed a error 999999.See attached screenshot and XML files.
Thanks lots.
T.T
Tags (1)
by Anonymous User
Not applicable
Original User: EssMarco
Hello!
I have the same problem. I have exported a terrain model from AutoCad Civil 3D 2012 into a landxml-file. When I import the landxml-file (LandXML to TIN) into ArcGIS 10 I get the error message 999999 (The XML file is corrupted).
Does anyone have an idea what could be the problem?
Marco
NickMadani
Hey, same problem here unfortunately.
Did anybody figure out a way?
by Anonymous User
Not applicable
Original User: Gaya6337
This issue is a bug [#NIM072260  LandXML To TIN tool results in error 999999 with certain .xml files. ]. However, the bug has been fixed in 10SP4.
Regards,
Gayu
PriskaTiefenbach
Same problem. Therefor:
When 'exactly' will the SP4 be released?
Why is your mentioned bugfix #NIM072260 not in the list from 14th feb http://downloads2.esri.com/support/downloads/other_/183410.0_SP4_Announcement.pdf ? Will the problem realy be fixed?
Thanks
by Anonymous User
Not applicable
The 10 SP4 is getting released in March 2012, here is the link of this information,
http://resources.arcgis.com/content/patches-and-service-packs?fa=viewPatch&PID=160&MetaID=1834
-Gayu
GayathriAlallasundaram
New Contributor III
The above issue has been addressed with 10.0 Service Pack 4. Here is the link to install 10SP4,
http://resources.arcgis.com/content/patches-and-service-packs?fa=viewPatch&PID=66&MetaID=1840
-Gayu
by Anonymous User
Not applicable
Original User: Frances728
Thanks for this
