I have created many 3D trail line feature classes (with a specific direction) and corresponding elevation profiles in ArcGIS. I wanted to cross check some elevation gains I calculated in Excel (by exporting the data from the elevation profiles because they seemed too large).
So, I exported to .kml to bring into Google Earth to compare. Well, the route is in the reverse order in Google Earth - the profile is reversed so therefore I cannot compare the elevation gain.
Has anyone else experienced this reversing of the order when exporting to kml and how to fix it?
Or does anyone suggest a good layer file to .gpx converter so I can try some of the other programs out there that calculate elevation gains?
Carmen
