Know to download orthoimagery
3449
04-26-2015 11:53 AM
JB
New Contributor III
​I am wondering if anyone could help me with this. I'm trying to download orthoimagery for Albany county from nys clearing house and when I do it does not show up when I try to add data. Thank you in advance
SepheFox
Have you unzipped it?
JB
New Contributor III
I have and there is data in the folder but when I click add data nothing shows up.
SepheFox
When you look at the folder in Explorer, what files are shown? A screenshot might be helpful.
SepheFox
Also, did you follow these instruction:
  • The MrSid Image Support Extension must be loaded from the extensions menu first.
  • When adding the orthoimagery as a theme, the "Data Source Type" should be Image Data Source, not Feature Data Source.
  • View the orthoimagery by selecting and opening *.sid  or *.jp2 file.
  • Vector data layers can be added by opening associated files, vector data layers can be re-projected if they are not in the same projection as the orthoimagery (raster) files. Make sure the "Data Source Type" is Feature Data Source when adding the vector files.
