adobe flash builder error of HScrollBarSkin and VScrollBarSkin
1807
09-02-2014 07:57 PM
LiYao
New Contributor III
Hi there,
when I build my adobe flash builder project, I get the errors as shown in the picture attached, but I still can run the web application with a strange display.
Is there anything missed in my project?
LiYao
New Contributor III
Hi Robert,
After I deleting the project and importing the original one again, the errors disappear.
Thank you very much!
RobertScheitlin__GISP
Li Yao,
   Do you have "src/com/esri/viewer/skins/HScrollBarSkin.mxml" in your project?
LiYao
New Contributor III
Hi Robert,
Thanks for the quick reply. Yes I have src/com/esri/viewer/skins/HScrollBarSkin.mxml in my project. The HScrollBarSkin.mxml code:
<?xml version="1.0" encoding="utf-8"?>
// Copyright (c) 2010-2011 Esri. All Rights Reserved.
// Licensed under the Apache License, Version 2.0 (the "License");
// you may not use this file except in compliance with the License.
// You may obtain a copy of the License at
//    http://www.apache.org/licenses/LICENSE-2.0
// Unless required by applicable law or agreed to in writing, software
// distributed under the License is distributed on an "AS IS" BASIS,
// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
// See the License for the specific language governing permissions and
// limitations under the License.
@private
<s:SparkSkin xmlns:fx="http://ns.adobe.com/mxml/2009"
             xmlns:s="library://ns.adobe.com/flex/spark"
             alpha.disabled="0.5"
             alpha.inactive="0.5"
             minHeight="15"
             minWidth="35">
    <fx:Metadata>
        [HostComponent("spark.components.HScrollBar")]
    </fx:Metadata>
    <s:states>
        <s:State name="normal"/>
        <s:State name="disabled"/>
        <s:State name="inactive"/>
    </s:states>
    <s:Button id="track"
              width="54"
              left="16" right="15"
              focusEnabled="false"
              skinClass="com.esri.viewer.skins.HScrollBarTrackSkin"/>
    <s:Button id="thumb"
              skinClass="com.esri.viewer.skins.HScrollBarThumbSkin"
              visible.inactive="false"/>
    <s:Button id="decrementButton"
              left="0"
              enabled.inactive="false"
              skinClass="com.esri.viewer.skins.ScrollBarLeftButtonSkin"/>
    <s:Button id="incrementButton"
              right="0"
              skinClass="com.esri.viewer.skins.ScrollBarRightButtonSkin"/>
</s:SparkSkin>
Li Yao,
   What version of the Adobe Flex SDK are you using. The ArcGIS Viewer for Flex has a minimum requirement of Adobe Flex SDK 4.6
LiYao
New Contributor III
Hi Robert,
I use Adobe Flex SDK 4.6. It is strange that yesterday no these errors.
LiYao
New Contributor III
Hi Robert,
