Thanks Dasa.
Example attached (AttributeInspector.png), in this the Panel is set to 250x350 and the AttributeInspector is 100%, yet the FieldInspector is shooting out the side of the parent conatiner. Ideally i'd like to control the width of the TextInput via the container.
At the moment they seem to always be a fixed size depending on the data type, in this example the Name attribute is a 50 char text field while the ID is a double, which results in them being different widths. I'd also like the ability to change the height of the Name TextInput as it's bigger than necessary, but again that seems to be a fixed property.
I've also attached another example (AttributeInspector2.png), where both the Panel and AttributeInspector are set to 100%, the problem here is that the Delete/Next/Back buttons sit a third of the way up from the bottom, despite the parent AttributeInspector container filling the entire panel. I would ideally like to be able to move these so they sit right at the bottom.
Thanks, Richard
