BaseWidget's close() function missing after API upgrade?
2450
8
06-24-2011 04:53 AM
MattMoyles
New Contributor III
I'm working on upgrading our App to Flex 4.5 and ArcGIS Flex API 2.3.1. Everything went smoothly thanks to some tips I read in another thread but there is still one thing I can't figure out.
We have code in many of our widgets that will close the current running widget if another widget is opened.
This is not even really the behavior I wanted in the first place. I would rather have the reverse where the openDetect function will close the widget that it is trying to open but I haven't been able to figure that one out.
So the actual error is that this.close(); does not exist. I tried tacking an id onto BaseWidget like id="myBaseWidget" but myBaseWidget.close() does not exists either.
I would very much appreciate if anyone could tell me what's up with the close function and If anyone knows how I could block the widget trying to be opened in openDetect that would be even better.
            private function openDetect(event:AppEvent):void {
                var id:Number = event.data as Number;
                var idx:Object = configData.widgetIndex[id];
                var wgt:Object = configData.widgetContainers[idx.container].widgets[idx.widget];
                var wid:String = wgt.url;
                var blocked:ArrayCollection = new ArrayCollection([
                    "widgets/EditSWEATIR/EditSWEATIRWidget.swf"
                if(blocked.contains(wid)){
                    this.close();
            private function widgetOpenedHandler(event:Event):void
                ViewerContainer.addEventListener(AppEvent.WIDGET_RUN, openDetect);
MattMoyles
New Contributor III
Well it appears that the close() function was something one of my co-workers added in, and I overwrote the modified BaseWidget while upgrading.
But I'm still looking for a better way to handle this if anyone has any ideas.
RobertScheitlin__GISP
Matt,
   Can you break down your request a little more for me? Are you try to prevent a certain widget from opening and if that is the case when would you allow it to be opened? I'm sure I could help if I understood...
MattMoyles
New Contributor III
We have a few sets of widget where one widget is an 'Editor' and the other is the 'Viewer'. It would not make sense, and would cause problems if both of these widgets were allowed to be open at the same time.
That code I posted above would be in both the Editor and Viewer widgets preventing them from being open at the same time. Currently the way it works is if you have the Editor widget open and decide to open the viewer widget it will close the Editor widget.
What I was originally looking to do was if you had the Editor widget open and tried to open the viewer widget it would block the viewer widget from opening, instead of closing the editor widget.
I hope that makes sense. And thank you for the response!
Matt,
Is this still your preferred behavior?
MattMoyles
New Contributor III
Yes, that's the way I'd like it to happen, is there an event I'm missing that could do that?
Matt,
   Well it was a lot harder than I thought it would be...
I managed it in the HeaderControllerWidget.mxml, you have to replace two existing function and add a new one and a couple of import statements. And of course replace the widget names in the code with your own.
What this does is prevents the other defined widget from running if the second one is visible and vice versa.
            import com.esri.viewer.IBaseWidget;
            import com.esri.viewer.IWidgetContainer;
            import mx.core.IVisualElement;
            import widgets.WidgetContainer.WidgetContainerWidget;
            private function widgetItemDG_widgetItemClickHandler(event:Event):void
                var widgetItem:WidgetItem = ItemRenderer(event.target).data as WidgetItem;
                if (widgetItem.isGroup)
                    groupWidgetAC = new ArrayCollection();
                    // check the array of widgets if they are open before hand
                    for each (var widgetObj:Object in widgetItem.widgets)
                        var widgetItem1:WidgetItem = new WidgetItem;
                        widgetItem1.id = widgetObj.widget.id;
                        widgetItem1.label = widgetObj.widget.label;
                        widgetItem1.icon = widgetObj.widget.icon;
                        widgetItem1.url = widgetObj.widget.url;
                        widgetItem1.open = widgetObj.open;
                        groupWidgetAC.addItem(widgetItem1);
                    menuToolTip.visible = false;
                    widgetList.visible = true;
                else
                    checkIfRunOk(widgetItem);
            private function checkIfRunOk(widgetItem:WidgetItem):void
                var allow:Boolean = true;
                var sid:Number = ViewerContainer.getInstance().getWidgetId("Enhanced Search");
                var sid2:Number = ViewerContainer.getInstance().getWidgetId("Draw and Measure");
                if(!isNaN(sid)){
                    var idx:Object = configData.widgetIndex[widgetItem.id];
                    var wgtContainer:IWidgetContainer = configData.widgetContainers[idx.container].container.obj;
                    var wc:* = wgtContainer;
                    if(wc){
                        var ve:IVisualElement;
                        for (var e:int = 0; e < wc.widgetContainer.widgetContainer.numElements; e++)
                            ve = wc.widgetContainer.widgetContainer.getElementAt(e);
                            var baseWidget:IBaseWidget = ve as IBaseWidget;
                            if (baseWidget.widgetId == sid)
                                if(ve.visible && widgetItem.label == "Draw and Measure"){
                                    allow = false;
                                    break;
                            }else if(baseWidget.widgetId == sid2){
                                if(ve.visible && widgetItem.label == "Enhanced Search"){
                                    allow = false;
                                    break;
                if(allow)
                    ViewerContainer.dispatchEvent(new AppEvent(AppEvent.WIDGET_RUN, widgetItem.id));
            private function widgetList_widgetItemClickHandler(event:Event):void
Matt,
   I forgot you will need the getWidgetId function added to your ViewerContainer.mxml also.
//My Add
            public var _configData:ConfigData;
//End My Add
//My Add
            public function getWidgetId(widgetLabel:String):Number
                var id:Number = Number.NaN;
                for (var i:Number = 0; i < _configData.widgets.length; i++)
                    if (_configData.widgets.label == widgetLabel)
                        id = _configData.widgets.id;
                return id;
//End My Add
            private function postConfigHandler(event:AppEvent):void
//My Change
                var configData:ConfigData = _configData = event.data as ConfigData;
//End My Change
                var ui:Array = configData.viewerUI;
                var splash:Object = {};
                for (var i:int = 0; i < ui.length; i++)
                    if (ui.id == "splashpage")
                        splash.url = ui.value;
                        splash.config = ui.config;
                        splash.title = ui.title;
                if (splash.url)
                    loadSplash(splash);
RobertRectenwald
I've used this functionality to close my widgets after a map click event:
[INDENT]private function mapClicked(event:MapMouseEvent):void
[INDENT]this.setState('closed');[/INDENT]
[/INDENT]
I've also verified that it fires the widget close handler.
